Like the one I have.
Fantastic value.
Netto Hoist - £39.99
This Thursday - 15th January
Lifting Weight: 125Kg - 250Kg
I have one of them and I've lifted zetec's in and out no problem. It has a loop hook to increase the lifting weight
i got one of these about 2 weeks after xmas for £17.50!!! from netto. it lifts the rover v8 with gbox no probs!!!
going to have one of those
Looks very much like this, which we bought one of a while back.
- We use it to lift a boat against the garage roof, but its s decent bit of kit.
As said, the two numbers are its two rated lifting amounts. Depending if you use the pulley to double it over or not.
Daniel
I cant get one up here.
Maybe get someone to send one up for you ?
How does that work then? It cant do 100Kg?
