How easy is it to change the water pump on a 1.8 zetec (circa 1992)?
Does anyone have an electronic copy of Chapter 3 of the zetec haynes manual that covers the removal/refitting of the water pump?
Does the timing belt need to come off?
Mine seems to be rumbling and the pulley shaft is slightly buckled. I suspect the bearings might be on their way out.
Its quite easy but youl need the cambelt off which means a replacment.
