I've got this little project that has been lurking in my mind all Winter - and now I've decided to get on with it! (I'll tell you what
it is if it works... )
One key component is the round cup shown below. The most significant bits are:
you could make 2 steel formers by turning in a lathe, then press an aluminium disc between them in a workshop hydraulic press.
In fact the hole could be pre-drilled in the disc and could be used to locate on a lug in the formers.
manufacturing investment levels depend on how many you want to make really.
Turn it from a solid piece. Anything with "billet" in the description always sells for 100x the price!!
Ahhh, with the numbers I guess it's for home use. You will have saved 100x the price though!
I know what it is! The sharpened edge at the top makes it obvious! The 10mm hole is not for a bolt, it's to let the air out as each cookie is
cut.
Simple. Try us with something harder next time.
John
Not sure if it would work well enough for your application, but what about building a wooden mould and making it from grp?
p.s. I keep thinking "Chronicles of Riddick" when I look at that knife edge. You'll know the scene if you've seen it
[Edited on 11/4/09 by iank]
your all wrong its an ash tray for his 7 the hole at the bottom is to suck the ash away
Just turn them from some aluminium bar, takes about 1/2 hour each at the most.
I made something almost exactly the same to punch small velcro sanding discs from large velcro sanding discs.
It's made from 63mm stainless tube, with one end sharpened.
I didn't bother filling the middle bit, just hit it around the edge
Simon
Some good guesses there - but all wrong!
Hint: It's something to do with this thread.
I think it has more to do with telecommunications, the hole is obviously there to get plenty of string through it.
I guess a hub centre cap and the hole is to mount a bearing?
And you need two, one for either side.
thought about tube with the end welded on? could be ally or stainless!
Still think replacing the hub nut with an extension would be better IMHO of course
I agree that an extended nut would be the best option (I've even bought the hex steel to make one!) but it's keeping the water out of the front bearing that still bothers me - I've looked at all sorts of seals but I still haven't found one that will do the job (IMHO).
How about using a piece of round steel instead of hexagon ? then find an oil seal to match the diameter of the extension piece and if needed machine up a hub center cap to take the seal?
It looks over elaborate to me. Why not drill a hole in a wheel centre cap and put a bolt in it to the correct length, use a sealed bearing to fit the bolt, fasten your support to the bearing outer race or make a small housing for the bearing to sit in and fasten the stays to that.
More info (see piccy below)
I remembered why I went off the idea of an extended hub nut, in favour of a bearing on the wheel - I was worried about what would happen if I happened
to clip the stays while parking, etc. With the hub nut idea there's a real chance of damaging the stub axle (which would be a real PITA to fix),
but with this idea the only casualty is likely to be the spindle or plastic hub cover.
The original posting was regarding making of the 'locking cup' as it's called in the diagram - the hub cover has fingers that click
into place into the wheel, and I was concerned about whether it would stay in place. Putting the cup inside would stop the fingers from coming out of
the wheel groove... this may be over-kill!
You could machine the nut extension so it reduced the overall thickness at on point so that in the event of an accident it would shear?.. Bit like a steering column shear bolt.
