I need to fill a few pinholes in my chopped sump and add a peice of ally just behind the drain plug to thicken it up a bit, is Lumiweld ok for this type of job and is it easy to use as my welding is rubbish.
Hi
I've used it sevceral times now.
Not that difficult to use.
Something as large as your sump may benifit in pre warming, and likely to need a lot of heat.
Would be to practice on scraps first.
Martin
Cheers fellas, i will get some ordered and also warm my sump up in the oven when SWMBO is out.
For sure. Great stuff. Def need pre-warming but a domestic oven does it nicely!!!
put some oil and a chicken in the sump,dins is done,o/h thinks your a hero,job done
