It's amazing how quickly you forget how to weld...
Had to repair my front nearside wing stay (AGAIN!) so decided to use my MIG... only a 2 minutes welding job, but needed 30 minutes trying to set the
wire speed and voltage correctly before I started!!!
Ended up with a respectable set of welds, but you ought to see the pigeon poo on the bit of metal I used for practice...
I know the feeling!
I don't supposed you lost your wing leaving stoneleigh last weekend?
I wonder how you could sort it out once and for all??
I have a cunning plan...
Ah ok!
When leaving stoneliegh a kit car I was following lost his wing. Didn't look in good condition after bouncing down the road!
Ah ok!
I'll not bother even trying to fit one on my MK then.
Made my wing stays from a length of conduit with a bender ( a conduit bender not a gay bloke).
Strong enough to sit on with no ill effects and I'm a big lad.
I agree about mig welding its very much like plastering when the time rolls round to do it again you've forgotten the technique.
Bob
[Edited on 12/5/09 by splitrivet]
