I have 1/2 inch block of aluminium that I want to make a large hole in (chain drilling) and shaper the ouside.
Would it be a goo idea to use milling bits in a pillar drill or wouldthat knacker the bearings, even if I go very slowly?
I have a travelling vice so can turn the handle very slowly.
Also best way to saw the block to size - hack saw - I doubt my jigsaw would do a good job?
Any tips on ensuring the cut is straight - norallmaly with thin sheet < 4 mm the straighntess of the edge is not that important.
looks like I wioll be busy withthe saw and file later on ... off to time my cam now.
laters peeps .....
It s not very successful as the neck on the pillar drill has too much flex. We use the milling vice on the myford lathe to do such operations.
Even the biggest floorstanding machines have this problem.
perhaps theres a member near you with a lathe and a milling attachment to do the job for you.
other than that its hard filing and drilling......
cheers mango
okey dokey, I'll do it by hand - I've done a land rover drop arm puller in thicker steel that took about 6 hours so this should be easy peasy being aluminiumuiunum.
[img]make a large hole in [/img]
Wood working coping saw with plenty of cutting lubes works well if you take your time , just needs tidying up after cutting. Worked on my inlet manifold (12mm)
I've got some milling bits and a cross vice under my pillar drill but still haven't got round to trying milling.... I doubt it would be super effective but going really slowly perhaps it would work....
french chalk on the file stops it from clogging up
tony
tony
Also you'll find that the vibration from milling will loosen the drill's chuck and the cutter will come loose.
Been there, tried it, decided that the returns weren't worth the effort and agro.
I now use one of two methods - a vertical slide in a lathe (good results, but a faff to set up) or an ancient hand shaper I bought yonks ago (can only
do small pieces, and good exercise, but the results can be excellent if I do it properly).
