Hi All,
We tend to move about a bit (once every 2 years or so) so I want to buy some free standing garage shelving that is easy to move around..
Any ideas? The best so far seems to be:
linky
Cheap but not so sure on quality..
These shelving units will allow me to reconfigure depending on space i.e set up for bench or shelving; making space for the up and over door etc...
Dan
[Edited on 22/9/09 by Bluemoon]
they are alright I had them - bit on the narrow side and turn to fall apart when you lift them up so need fixing securely
they do take plenty of weight though and not bad prices - I got mine off ebay saved a bit from machine mart prices
Those were exactly the ones I was about to suggest, wwe've got very similar ones (albeit twenty years older) they hold a decent weight but are easy to pull apart and move if the need occurs.
I used this lot>
http://www.shelfsave.com/index.php?jssCart=a2e8a1d67bd29728ed687e09a314f34c
Cheap prices and not bad quality either.
Mike
Guys,
I have used these people a couple of times linky thing.
They were great and deliver to your door (I live on a lane on a hill so this is a big thing!!)
I'd second Big Dug!
Have a look at their bargains - sometimes they do just the racking / shelving and you can make the shelf top yourself out of timber.
Wyn
I much prefer the 300kg Clarke ones over the 150kg ones (got both) similar design but a lot sturdier.
Though they seem to have been upgraded to 350kg now.
http://www.machinemart.co.uk/shop/product/details/csr5350bp-350kg-boltless-shelving-blue
Those big dug ones look better value though!
I acquired a load of Speedframe very cheaply about 15-20 years ago when the company I worked for was closed down. It's excellent for custom
racking but I think it's quite expensive to buy new.
John.
