Seen this on the bay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190397646325&ssPageName=STRK:MEWAX:VRI
Anyone got one? any good??
That's way too cheap for a proper TIG
assuming its on of those inverter ones - my dad's got one for stick welding in places that you can't get a proper welder close enough (like
the top of a ladder)
even with the TIG torch - you can't TIG alloy with them apparently
Is it just the inverter add on?
This is a picture associated with the model number on the ebay listing
HE
RE
Product Description:
Model: CT-312 (D) , CT-416 (D) , CT-518 (D)
1. Advanced inverter technology, reduced size and weight, easy to carry.
2. Novel and effecitive, and low cost;
3. Three functions in one machine, tig welding, mma welding and air plasma cutting
4. Compact and easy for operation.
5. "D" Series are for 110 / 220 duel voltage input, automatic input voltage changing
6. Complete accessories: welding torch, welding cable (3 m) , earth clamp, welding holder, , cutting torch, carton box.
Full spec
HERE
G
[Edited on 17/5/10 by Mr G]
Good to see the cheapies are starting to include HF start.
DC only inverters have been available around this price for quite a long time. You can get AC/DC TIGs for £400. However, the quality of these is
typicaly Chinese, i.e. varies from crap to mediocre.
If you are tempted my advice would be to check out the price of Argon in your area. The thought of paying yearly rent on a bottle that would not be
used very often put me off, but there are some places in the country that you can just put a deposit down on a bottle and have no rental charges.
Sadly none down here that I have found.
personally i would go for one of the AC tigs that doesn't have the plasma cutter try a WSE 200. that way you can have a go at ali welding.
in my experience the 3 in one machines dont do anything well, but do everything OK. i'd rather just jave the welder that works peoperly.
Originally posted by MikeRJ
If you are tempted my advice would be to check out the price of Argon in your area. The thought of paying yearly rent on a bottle that would not be used very often put me off, but there are some places in the country that you can just put a deposit down on a bottle and have no rental charges. Sadly none down here that I have found.
My bro in law uses one of these as a stick welder on his boat and they are excellent. Because it is DC it works really well with stick welding with a
classic weld and the slag peels off perfectly.
He welded up 4 aux fuel tanks out of quarter plate for the boat ( its a large boat) and they all passed air pressure test first time - not bad for an
amateur and says a lot for the welder.
The tig torch that came with it looks a bit naff I'll try it out this weekend but don't have high hopes.
DC only inverters have been available around this price for quite a long time. You can get AC/DC TIGs for £400. However, the quality of these is typicaly Chinese, i.e. varies from crap to mediocre.
You can get bottles from Bodmin, I have one for when my air product account finishes. The gas costs more of course but there's no rental so if you don't use it often it's the way to go!
Here's a link to the supplier![]()
http://www.rusesgasandtools.co.uk/
