When I had a parts washer before I used paraffin, which I found worked very well.
I'm considering getting one again, and the adverts suggest me using stuff that is diluted with water. Has anybody here tried this, and if so, is
it any good, or should I stick to paraffin?
paraffin, white spirit, deisel? Alot of people use deisel and petrol mix.
You can buy proper cleaner but its not cheap. stick some kerosene in it (parafin) you will pay less from a heating oil suplier.
The detergent stuff I bought with mt parts washer was pants
Now use diesel petrol mix cos I got a tankfull
Works well
The water mixing stuff is rubbish in my experience, either as above or Jizer is very good.
Chris
Jizer is very good.
It cleaned the grit and oil off the super seven with no sweat.
The problem with using petrol and paraffin in large amounts is fire risk
Not only is there a fire risk with petrol /diesel mix the fumes can be pretty lethal as well
I use diesel and petrol mix but i do have an endless suply of it. Fumes give me a headache after a while though.
I use bio diesel. If you can get it it's wicked and nothing is safe from it's cleaning ability! It's non toxic and does not fubar your
hands either!
