What does the word 'rethreading' mean in this context? I want to cut threads into round bar, tube, etc. Is a set with
'rethreading' in the name suitable?
Reason being that I've seen a set that seems to be a good mix of quality brand vs price, but the name concerns me!
Chris
Rethreading dies are likely to be the non-split type and are probably only suitable for chasing an existing thread.
Split dies are better for threading a virgin piece of stock as you can take several passes to get the correct fit.
Thanks for the explanation.
What's the physical difference between split and not split?
Chris
Yeah, sounds like what i would call a die-nut for running over damaged/painted/etc threads rather than cutting new.
Daniel
Thanks guys. Much clearer about what I need to buy now!
Cheers, Chris
Following on from this.... does this look like a suitable set?
eBay Item
Chris
Hi
I'd steer clear of 'budget' sets - in my opinion they are only really suitable for restorarion or cutting softer materials, (brass
etc.). Look at individual items from the likes of Dormer or Goliath - will last a lifetime of occaisional use, (if used with cutting compound). Cheap
wrenches will suffice though.
Regards Mick
If you have a Cromwell Tools near you they offer an extensive range of sets and individual taps/dies of good quality.
Originally posted by MixI'd steer clear of 'budget' sets - in my opinion they are only really suitable for restorarion or cutting softer materials, (brass etc.). Look at individual items from the likes of Dormer or Goliath - will last a lifetime of occaisional use, (if used with cutting compound). Cheap wrenches will suffice though.
I wouldn't normally consider Sealey to be budget. Ok they're not top end, but not cheap crap either. Should I be changing my opinion?
Chris
Chris
