I've went and stripped threads out of my engine head. It's a 10mm bolt hole.
So do I just get an m10 helicoil? I've seen different ones advertised ie. m10x1, m10x1.25, m10x1.50.... etc
How do I figure out which I need? and what size drill bit do I need.
Dont want to buy a whole kit for one repair.
Many Thanks
Edit- what about a timesert? Any good??
[Edited on 15/1/11 by Craigorypeck]
You need to know the pitch of the bolt thread 1.25, 1.5 or 1.75 or 2 using a thread gauge or by comparing with an M10 bolt or tap of known pitch.
Single size helicoil kits come complete with the correct drill and tool cost about £12 to 25 off ebay.
Helicoil is best suited to your needs.
[Edited on 15/1/11 by britishtrident]
Yes, thats the pitch, most M10's are 1.5mm pitch if im correct.
If you have a bolt and a decent steel rule you can simply measure ten or so threads!
You will need to get the full kit as the correct drill size and tap is supplied, along with a selection of inserts and the tang breaker tool.
Admittedly you might be able to source them all separately but kits are not too expensive at £13.52
here
[Edited on 15-1-11 by RazMan]
A set of thread pitch gauges cost peanuts , will last a lifetime and will ensure you get the correct Helicoil kit. I've been in the motor trade over e 40 years and still use mine . Don't remember ever getting a drill bit in any Helicoil set , I've always had to buy it separately, the size is normally printed on box.
Heres the culprit. calipers at 10mm... How is the pitch worked out? Thanks
Looks like 1.5mm standard to me metric
what dose the bolt hold on ?
10mm is a very small dia for a head bolt, what engine ?
Not a head bolt, YB cam pulley tensioner.
