Hi all,
Ive had this a couple of years now, and this is the first time ive had the opportunity to use it. I originally bought it for the scratch build, which
im no longer doing.
Nibbler
Its fantastic. Above all, its safe, and made what would have been about an hour of shaping into a three or four minute job. Well impressed, and
highly recommended.
I had one of those - great tool! Just make sure you keep it well lubed during cutting as it gets very hot.
Is it a Turner? I've had mine about 12 years, if you oil the cut line especially on aluminium it will last ages and new punch and die sets are still available for them.
Also put a bag under it to collect the bits it cuts out. The half moon shapes a) get everywhere and b) are sharp!
I'd also reconmend a decent powered drill. I got a cheap 500w one and it wasn't powerful enough to do the job but the 750w one i had was
great.
Only downside is its not easy doing straight lines - but air sheers are great for that.
Exactly what I was going to say, I can hardly believe how far the nasty little things seem to travel! It's a very good quality tool though, it was the only powered nibbler I could find that would cope with 16 gauge steel without disassembling itself, though you need a decent drill to make to cut smoothly at that thickness.
Any info on make & model. Sounds like I need one!
thanks
Metal Cutter Turner Nibbler on eBay (end time 14-Feb-11 13:43:55 GMT)![]()
You can still get them in Machine Mart for a lot less than that. £46.80 sounds better, mine was £30 from Newark kit show many years ago.
Think i paid something between 30 and 40 quid from stoneleigh a couple of years ago - also got two of the clamps, one for the drill and one for the nibbler.
