whats involved in changing the liner? want to get my cooling sort of working tomorrow, but still need a lower hose T for the bottom of the header
tank. never tried welding aluminium before, but i've got a telfon liner, and got the right gas somewhere, why not give it a go, just to get the
system filled up, see if it works
how do you change the liner though? is it easy enough? is there anything i'm going to end up damaging and needing to buy to change back again?
I think this is what you need Blake.
awsome thanks
look fairly straight forward i hope...
check the crimps on the power lead I had to solder mine back on last night
