Prep Work
cassidym - 9/7/04 at 10:03 PM
In some of the build pics the steel tubing is all shiny and clean while in others it is a bit greyish. Now the tubing that I bought in the past for other projects were also greyish coloured.
Is this something to be concerned about?
I usually do'nt sand the joint I'm about to weld to shiny metal although I know the cleaner the joint the better the weld, but I've read somewhere that the greyish part also serve as a kind of rust inhibitor. What do you suggest.
Also, I've read somewhere that if there is a gap of more than 1.5 mm between 2 tubes making up a joint, it is safer to cut a new to piece to get a better fit.
white130d - 10/7/04 at 12:50 PM
The grey coating is a rust inhibitor, depending on the supplier, some of it is weld thru. I always wire brush the joint to be welded, no matter what it is coated with, you can never have it to clean....
blueshift - 10/7/04 at 01:08 PM
cassidy, if you take the time to file the tubes carefully to get a perfect tight fit, you will have less of a problem with distortion.
I think the ideal is a tight fit with a bevel to help ensure good penetration.
