I managed to drop the aeroscreen and take out two chunks
I plan to chase out the crazing with a Dremel and build up the missing bits and fill in the crazing with flowcoat.
Would this work?
Yes flowcoat is ideal to use, wait till it's cured then flat it down with wet n dry and polish it up...simples..
DIFFICULT TO SEE - I CAN'T GET FAR ENOUGH BACK
Should work though!
[Edited on 11/5/11 by nick205]
Originally posted by nick205
DIFFICULT TO SEE - I CAN'T GET FAR ENOUGH BACK![]()
Should work though!
Originally posted by Triton
Yes flowcoat is ideal to use, wait till it's cured then flat it down with wet n dry and polish it up...simples..![]()
his username gives away the size of his monitor
