Graphite Grease ?
mcerd1 - 13/7/11 at 11:06 AM
Where can I find some high temp graphite grease ?
the stuff you use for clutch bits and so on (rather than the chassis lube stuff)
last time I used some castrol stuff that my dad had left, but its almost all gone (the tin must be 30 years old!)
any ideas ? / what do new cars use ?
cheers
-Robert
jabs - 13/7/11 at 12:19 PM
ebay as always although don't know if it's high temp but says it has a high flashpoint
Graphite Grease, semi-solid Suitable for all uses 750g | eBay UK
[Edited on 13/7/11 by jabs]
Litemoth - 13/7/11 at 12:22 PM
I think Castrol LM or Copaslip is usually used.
Maybe this is a good alternative:
LINKY
[Edited on 13/7/11 by Litemoth]
Peteff - 13/7/11 at 09:00 PM
Originally posted by LitemothI think Castrol LM or Copaslip is usually used.
Copaslip is not suitable for anything needing lubrication, it is anti seize and dries out into a sticky mess if used where it gets wiped backwards and forwards. I've never used grease or oil for clutch parts, clutch dust sticks to it and causes problems.
Litemoth - 14/7/11 at 08:39 AM
As you say, clutch parts often don't need lubrication but maybe he needs an anti-seize due to the fact that out cars spend a long time sitting. The tiniest amount would suffice - not enough to generate sticky messes. Maybe it's intended for a linkage/release application.
The dry moly grease linked to above is contaminant tolerant.
[Edited on 14/7/11 by Litemoth]
mcerd1 - 14/7/11 at 09:08 AM
cheers guys
as you say copaslip is not suitable, but just a tiny, tiny wee smear of the grapite stuff on the splines is enough to stop any seizing without attracing to much dust - I guess its a bit of an old fashoned thing to do but it works
the stuff in jabs's link looks like the right sort of stuff
but thanks for the dry lube link, I should look into that stuff too (things like that tend to move on a bit in 30 years :lol: )
[Edited on 14/7/2011 by mcerd1]
