As above whats best stuff I could get from B+Q or Screwfix for bonding wings on and the likes?
Sure that neither sell a suitable eqivelant to Sikaflex/Tigerseal/Stixall
Not worth bodging with bathroom sealer imho
I didn't know if they sold stronger stuff! Does halfords do anything useful?
Bicycles!
Our local motor factors sell an equivalent - various makes, including Tiger Seal. Bit more expensive than on-line suppliers, but not stupidly so.
Allwoods in Newark sell Tiger Seal - probably as close to you as B&Q?
Screwfix do "Sika Sikaflex EBT Adhesive" at £7.49 but I'm not sure if that's the grade you need since I'm still a long way
off needing it.
John.
B&Q do not sell sikaflex - well at least my local one does not - but I did pick up two tubes from Travis Perkins.
Originally posted by John P
Screwfix do "Sika Sikaflex EBT Adhesive" at £7.49 but I'm not sure if that's the grade you need since I'm still a long way off needing it.
John.
I have used this many times and works very well it is supposed to be an equivelent to Sikaflex 221 but a lot cheaper.
http://www.idealsealants.com/polyurethane-sealant-pu-grey-310ml-siroflex-polyflex-hm_c57p57.php
Or this from toolstation lots of branches located around the country, just started to use this so I will see how it goes. only in white though.
http://www.toolstation.com/shop/Adhesives+Sealants/Sealants/Polyurethane+PU40+Sealant+310ml+White/d180/sd2350/p67949
