Hi All
Im going to be ordering my kit soon i hope
anyway have been boarding the end wall of the garage and getting it all ready for building but it is quiet dark (even with a 6ft strip light)
so thought i would paint the floor to help keep the dust down and brighten it up and also paint the walls white.
has anyone done this before any pics ? also how did you prep the surfaces and what paint did you use on walls/floor ?
have read on the net to mix up PVA glue with water a 50/50 mix and paint all over to seal the concrete first ? is this correct ?
thanks
Watch Mr Bean he has a great way of painting really fast!
Pva/water mix is correct for most dusty surfaces.
Screwfix garage floor paint is good
I coated my garage floor with a mix of PVA and water before paint, although I can't remember what the mix is, but it does tell you on the PVA
glue label. I'd recommend a proper 2 pack floor paint (paint and hardener) rather than an all-in-one tin. I mixed the paint up, poured it onto
the floor in various places then using a soft sweeping brush spread it around the floor, thrn went on holiday for two weeks, when I came back it had
cured perfectly. Sorry I don't have any photos showing the floor.
The walls and ceiling were painted with the big tubs of economy emulsion from B&Q, it's a lot cheaper than masonary paint but be aware it
takes loads of coats to cover the brickwork/blockwork properly.
Once the painting was finished I fitted three 5ft flourescent strip lights to replace the one lightbulb it originally had, that made things much
better.
Here are some photos,
Before
During
After
[Edited on 27/7/11 by SausageArm]
I have to say I'd use good quality paint. I like Wickes pure brilliant white because it covers nicely (just don't get the contract stuff). Cheap paint is cheap because it's rubbish. It's thin like water and you need shed loads of it to get a proper degree of reflection. I've used screwfix garage floor paint and it's worked well. I didn't PVA but now it's coming up a little bit. Then again after six years you might expect it to.
We use Leyland floor paint at work and at home- work shop floor gets done every year- mostly for cosmetic reasons but it does stick well. There is a
nice blue colour. Every second year we put in some of their non slip additive or you can just add dry silica sand and keep stirring. Needs lots of
ventilation while drying as it smells terrible.
atb
Mike
Also, once you've painted the garage, it will still seem a bit dark as just 1 6ft strip light won't be enough for what you're after.
I've got 5 6ft strip lights and a 100W bulb in the centre of my garage and I still want more lighting! It's enough to work on my car on
easily, but a little more wouldn't go amiss. I do also have a 400W site lamp for use under the car and for extra light when I'm welding.
Oh, and how many sockets do you have in there? I've altered my garage to have a double socket in each corner as I hate having extension leads all
over the place.
thanks for the replys all
i currently have no electrics to the garage (apart from a massive extension type lead that i have to run to the garage each time i want to work in
there) but have a friend coming around next week to fit sockets lights etc.
was thinking of 2/3 strip lights one each end width ways and one in the middle length ways ?
will go out and have a look around for some paint tomorrow
would this be any good ?
ebay item number 180697813340
thanks
If the walls are blockwork a good dodge, taught to me by a painting contractor, is to whitewash them before painting. Uses cheap whitewash to fill all
the little holes, so that you use a lot less paint.
Originally posted by gazza1591
...... some paint tomorrow![]()
thanks
I painted the floor red and the walls white. Only use dirt cheap white emulsion on the walls- got through a quite a bit of it but it does a good
enough job if you slart it on
The floor is a different matter- I used the cheap paint from screwfix but have had significant flaking. I'm not
sure if this is because the PVA layer didn't go down as well as it should have or if the paint itself was a problem. Others have used it without
this happening so I'm guessing the first!
White walls help considerably, but as mentioned above I'd get at least another strip light in. My workshop has six normal bulb fixings and two
strip lights- tbh the strip lights aren't really needed as the six normal fittings with halogen bulbs make it like daylight in there!
I'll attach a pic for good measure
Did my uneven garage floor with this:
http://www.screwfix.com/p/leyland-heavy-duty-floor-paint-frigate-5ltr/88106
I didnt bother doing much prepping just gave it a good broom and brush over to clear most of the dirt, dust and spiders.
