I want to countersink some of my rivets, but the rivets have a very shallow angle. Most counter sunk drill bits (or even just larger drill bits) seen to have a close to 45degree pitch. Am i right in thinking that a 90degree counter sunk is 45degrees on each side? In which case do i need a large or smaller pitch to get a shallower angle?
Silly question, but you are using countersunk (CSK) head rivets?
Which look like this
IIRC they need something like a 120degree countersink.
[Edited on 17/12/11 by iank]
Hi, the normal countersunk rivets are already 90 degrees personally they are the only ones ive ever seen.
where did you get the shallower ones from are they special for thin sheet or something?
Ray
ohh just seen the above pic and indeed they are shallow.
Ray
I used a standard coutersunk drill with csk rivets- no problems
An ordinary drill bit usually has an angle of 118°.
HTH
Neil
IN which case these must have close to a 140-150 degree pitch, its really very shallow.
there are 90, 100 and 120deg rivets available, if you want to check them, compare them upto a light against a woodscrew which are normally 90deg, and a drill bit iirc should be 51deg each side ie 102deg. if its neither of them it ll be 120deg.
What size are your rivets - i might have what you need. I countersunk most of my rivets using a "microstop" (google for images) I have various countersinks for it. Aircraft rivets are usually 100 degrees. I have some 130 degree cutters but largish.
Cheers guys, will have a compare.
Typically, being specilist it looks like im gonna have to spend over the odds for a tool il use only a few times!
Robert Charles 14mm x 120 TiN 7 flute Countersink | eBay
Can you not re cut a normal drill bit to the angle you require?
cool,
i was only asking a question, off what i would of possibly done !!!
just as well, as i would off buggered up the material
You can use a drill bit by first grinding it to the correct angle and then grinding a small flat on each front cutting edge to remove the front rake
angle, it will then be ok for countersinking ally etc without snatching but wont cut hard materials very well.However if I had a lot of holes to do I
would buy the correct bit.
Paul
Placing a piece of emery tape between a modified drill bit and the hole to be countersunk normally stops any chattering. Might be worth trying on a piece of scrap ??
Cromwells do countersink cutters in various angles covering near everything used as standard in industry.
Nev.
Nev.
http://www.cromwell.co.uk/browse?page=7
Cheers!
Cheers!
Your search did not match any products.
Please try alternative keywords or a more general search.
Works for me!
Go into the site, put countersink into the search box, at the bottom of the page click page 7.
