I am planning of refurbing a set of alloys.
My problem is that they are fake split rims.
How do i deal with it? Do i remove the fake torx bolts before i powder coat them? cover them?
What is the best sollution? Should i assume they bolts are glued there as well?
These are the ones in question
[Edited on 21/3/12 by l0rd]
More than likely if you try to budge the bolt heads they will shear off. I'd say take em to the blasters/coaters . Cheers D
Light blast to clean off & then paint perhaps.. Or get pickin at the dodgy bits.
I think id be inclinded to but the refurb money towards a new set of rims without the silly fake bolts. Set of OZ superleggras or Rota Circuit 10s
look very similar to those but dont have the fake bolts.
[Edited on 21/3/12 by loggyboy]
Cannot afford a new set.
Powder coating will be about 100-120 euros while any new set of alloys will be 400+
right lads
started to rub the wheels down to get rid of the paint. Should i remove the primer as well?
With any job the end results comes down to the preperation.
Those fake bolts should just un-bolt. I have seen some that are made of plastic so just take care. Once the bolts are removed a nice chemical strip
followed by a grit blast. You have to ask your self is it worth spending thr time and money on those wheels?
A friend of mine had a set with the plastic bolts and they came out and went back no trouble when he painted and lacquered them.
