Hello,
I have broken my 15" 1/2" drive ratchet taking off a mercedes wheelstud, the innards are knackered now, it is not worn at all, how do I get
it fixed/replaced under the snap-on lifetime warranty?
I originally bought the ratchet with a load of other stuff about 20 years ago from a snap-on dealer in South Shields, I now live in Chandlers Ford,
Eastleigh, I have looked on Google to see if there is a local snap-on dealer franchise that can deal with this on my behalf but not having much luck
at the moment
Find a friendly local garage and ask if they have a Snap On dealer who will replace the innards. IIRC ratchets are only warranted for 5 years?
Ratchets should only be used after breaking the initial bond between the stud and wheel otherwise they can fail. Use a breaker bar, (clue is in the
name) first then use the ratchet to unwind the stud.
[Edited on 2/6/12 by spiderman]
Unless you have a rep your trading with I find the waranty is worthless. Undoing wheel nuts with a ratchet isnt fair use any way so again I doubt they
would warant it.(yes I know every one does it instead of fetching the breaker bar) I would look for a rebuild kit.
And if you find one let me know as I have a 3/8 stubby that has needed doing for years
Whats the model number ?
Originally posted by big_wasa
Unless you have a rep your trading with I find the waranty is worthless. Undoing wheel nuts with a ratchet isnt fair use any way so again I doubt they would warant it.(yes I know every one does it instead of fetching the breaker bar) I would look for a rebuild kit.
And if you find one let me know as I have a 3/8 stubby that has needed doing for years![]()
any friends state side that could post cheap ?
Only a tenner but the postage is daft. picture gives part number though.
For information I removed the wheelstuds with the mercedes toolkit supplied wrench, the freebie wrench supplied was only about 10" long but was
able to remove the wheelstuds without incident
p!ss taking T@@ts 10 dollars or 30 quid
http://buy1.snapon.com/catalog/searchLN.asp?partno=RKRA711&searchTrnsfr=true&search_type=Part&store=uk
Do you mean wheel bolts? Studs are usually a press fit into the hub.
[Edited on 2/6/12 by big_wasa]
I looked it up on there website.
http://buy1.snapon.com/catalog/objects/7800/RepairKits.pdf
It opens the uk option and in £ for me.
Go to there home page, choose uk option at the bottom of the page and search for item code.
My wife says if you ring 01536 413800 that will put you through to snap-on who will be able to advise you who your 'local' dealer is and
possibly give you his mobile number for contact.
Why 'my wife says', well its because she works for Snap-On in their repairs department. But DON'T tell everyone.
you can buy ratchet repair kits in halfords, while i wouldn't assume that ratchets are all the same inside, they don't seem to say they're only for certain types... they just say like '1/2" drive ratchet repair kit" or something. have a look, you might be in luck!
I had a problem with a snap on ratchet and wasn't sure how to get it fixed without spending a load of money, but my Dad solved the problem when he saw a snap on van stop outside a garage. He spoke to the driver who asked what ratchet it was and where we live, he then ordered the necessary parts and told my Dad when he would next visit a local garage. A few days later he fixed it free of charge.
