Evening all.
I've had my first bash at MIG today. A lot of you on here seem pretty handy with a welder, so could you have a glance at some of my practise bits
and let me know how I can improve them please?
The welder is a Clarke 150TE, welding with 0.8 mild steel wire, CO2 shield onto 3mm thick steel box section. 3mm is a bit thicker than I would have
liked to practice on but it was the thinnest stuff in the fabricators scrap bin! All of this is at max power with the feed rate between 5-8 as I was
playing around.
First off beads on to the 3mm box. The ones at the top are the earlier ones. I turned the gas up after the first few which seemed to help. I was
trying to weld in a kind of 'swirly' pattern, I'm not really sure why, but it seemed like the right thing to do at the time! (Most of
the spatter on the plate is from me practising on other bits on top of the plate- the welds on this didn't spit too much)
Welding 1
Second is a close up of one of the welds on the above box before I took the wire brush to it. It looks like a line of snot to me- advice welcome! And
what are the shiny bits about?!
Welding 2
Third is a piece of angle (3mm) welded on to the other side of the box section. Not sure what I think of this one, it doesn't look very pretty
but it wasn't going anywhere!
Welding 3
Wish I'd got a welder sooner, quite enjoyed myself this afternoon!
Sorry for the essay.
Craig
hi chap, some of it doesnt look too bad.
how are you holding the torch? you should have it pointing away from what you are weilding just incase you didnt know.
with mig you just need to play around with the amps and wire feed till it feels about right.
too much wire and it will stab as you weild and not burn into the metal.
too little wire and it will burn out tips and melt the metal.
also you can change your weld by the speed you travel and puting a slight arc movement on the torch as you weld.
best thing is practice.
keep it up
Try figure of 8 pattern or gentle weave side to side
Make sure you cover your arms, and legs, most of us must have tried welding in shorts at some point when the weather is good... you realise it's
a big mistake.
Also if right handed support you right hand wrist with the left hand, it allows a lot more control rather than free hand.
Apart from the few snotty ones at the top they look pretty strong to me, the ugly splatter is CO2, not a slight argon mix which makes things much
nicer.
Welding is all about practice, by the time you have made a car you will have mastered it, good start.
Turn the gas up. Those aero chocolate welds at the top of your first pic are due to a lack of shielding gas. Are you using disposable bottles by any chance? If so turn the regulator up to the max.
dump the co2 and use a co2 argon mix. it will produce much better welds with less splatter and make it easier for you to learn. looking at the welds it looks like you either need to up the wire speed or drop the power and move a bit slower, aim for an inch of weld in about 10 seconds
The best thing you can do is get yourself onto www.mig-welding.co.uk loads of information on there and a very friendly forum too
Cheers chaps. I'm just about to go and do some more practising so I'll bear what you've said in mind. Richie- yep disposable bottles!
The first welds were on 2/3ish as advised in the instructions that came with it, was quickly turned up to 4ish when they were 'aero-like'.
I'll try giving it a bit more. I'm using CO2 to start with, I've got a bottle of CO2/Argon mix for when I start welding proper things
on the car. I will practise with it a bit first though! I'll let you know how I get on.
P.s.- covered head to toe!
Ran out of CO2 so changed to my argon/CO2 mix bottle (£15!) to find it empty! It's barely worth driving to machine mart to complain either with the cost of fuel. Maybe disposables wasn't the right way to go? What do other people use? I don't expect to be doing tons of welding so I didn't think it was worth the rental costs of larger bottles.
Next step above disposables:
Either Adams Gas http://www.adamsgas.co.uk/index.php?option=com_virtuemart&Itemid=54
or BOC low rental
http://www.boconline.co.uk/products/products_by_type/industrial_gases/shielding_gases/argoshield/2_litre_argoshield_light_filled_cylinder.asp
[Edited on 9/6/12 by iank]
Disposables are a false economy and the valves on the bottles are often suspect as you have found out. Have a look on the mig-welding website for the "volkszone" offer from BOC. It's supposed to be quite a good deal for hobby welders. Other options are documented there too. There are more and companies out there who will sell you a medium sized bottle without rental charges and just charge you for a refill although you should still do your sums to see what is cheapest for you.
I have a very similar welder to yours. This is some welding of mine from last week. 3mm 50mm x50mm box section for a work bench I am currently trying
to make when it's not raining. The edges were bevelled to ensure decent penetration. 3mm is great to practice on as it you wont blow holes
through the metal as easy as you can with thinner steel.
Welder: Clarke 151 te
Wire: 0.8mm
Gas: Argon CO2 mix.
Power setting: 3 Min
wire speed: about 6.2 out of 10 on the dial.
Gas flow: High enough to make a Scotsman wince
Admittedly, this is the best weld of the bunch that I took pictures of. I am still trying to improve myself and need to practice more. Argon mix
gives a much smoother, nicer weld.
weld
top
For the exhaust welding have a look at the "Thin Metal Techinque" on the mig welding forum. You cant continuously weld really thin metal as
it blows holes. The idea is to create a continuous seam of individual spot like welds. There is a video on the mig welding forum showing how it is
done.
That weld of yours on the top photo of your latest looks really good. You are improving. That fillet weld to the left of the main weld looks good too.
mind you can get 8mm gasless wire too, very handy for welding outside, most off my welding is with this
welding 4
Something to bear in mind. If you are right handed it is considered good practice to weld from right to left. This is called pushing the weld. The
main weld on this picture looks like you are welding left to right and dragging the torch until you blew through at the end due to heat build up.
There is a bit of argument about this in welding circles. Some people don't think this matters and others think dragging is a big no no. You
might want to read up on a bit of welding techinique to make sure you dont pick up too many bad habits early on.
Gasless wire is very good, but my machine with normal wire and CO2 works well.
I converted mine to run on a cylinder rather than disposables (they lasted about 15 minutes for me) and my CO2 extinguisher has just run out after
about 18m of welding jobs (probably averaged 2-3 hours per month). The CO2 has nackered the argon gauges though, but i know by ear roughly what is
right and once set, it stays there. With CO2 on argon gauges, it freezes the regulator too after long usage.
Next step is to get some argon gas from Weldair in Luton, and make something that i promised for someone. Hoping to do that next week.
Thanks to IanK I have now ended up with this, for the princely sum of £34 + VAT
Argoshield
2 litre bottle of Argoshield light, £18 rental, £16 top up, should be enough for me. I'll be interested to see how much nicer it is to weld with,
the proper regulator should help as well. The place I got it from wasn't listed as a stockist of these bottles, but they were happy to get it in
for me- Gas and Gear in Coventry.
[Edited on 19/6/12 by me!]
I was about to tell you about the place I use in Leicester, called Fosse Gas. I get a medium size bottle (2ft high jobbie) that's filled to 2000 psi/9L for £36. There's no annual fee, just a one off deposit of £55. The guy runs it from his house, so I've just turned up and picked up a new one before.
Just finished my first part! The bottom part of this is by far my best weld so far
So I can now operate the clutch, when I get it xD
One of my best welds so far!
Good work!
I haven't actually welded anything properly go to on my car yet (exhaust has been tacked to check fit but that doesn't count!). When I do
I'll post it on here, so you can all laugh at my swiss-cheese style 'zorst!
I would definitely practice the thin metal technique that was mentioned earlier. It's how I do a great deal of my welding now as I prefer to turn
the power up a notch and do shorter runs, almost large tacks, rather than doing full runs as they distort too much. I find it a fairly simple
technique but it helps so much. This was last go at it, sticking a coil over tower to the inner wing and chassis rail in my Sprite:
Yeah I will have a go at that, it looks like its much better suited to 1mm thick exhaust. I need to chop up the exhaust off cut and practise again, as
now I'm on argon the settings will be different. I'll try both ways and see what gives better results. Would doing it as lots of little
'tack' type welds leave me open to small exhaust leaks? I suppose if I get some decent heat into the previous weld I should be fine.
Is it literally tacks or a couple of cm at a time kind of thing?
I tend to aim for 1cm or 1/2" or so long welds at a time. You do the first weld, then start the second on the leading edge of the first to ensure
a continuous line of welding. The idea is that the back should then look something like this:
Also, just found a pic that makes the technique a little more obvious. The horizontal line shows how one weld starts on the previous one. The idea is
to just pause between welds so the welds solidifies, rather than stopping to let it fully cool.
[Edited on 21/6/12 by DIY Si]
So come on, you've had a week. You getting on any?
Unfortunately not- no time! I will update when I do, but this weekend I'm at a wedding, the weekend after I'm going mountain biking, then I'm meeting up with friends from uni, then.... when did my life get so busy?!?!
Tsss excuses excuses excuses.... just get out there and play with your welder for an hour. If you want to you'll find plenty of time to have a go
Originally posted by JF
Tsss excuses excuses excuses.... just get out there and play with your welder for an hour. If you want to you'll find plenty of time to have a go![]()
Originally posted by me!
Welding will continue once the wiring is largely finished and I've plucked up the courage to cut a hole in my bodywork to make room for the silencer!
Originally posted by Alfa145
A hole similar to this?
I just sanded the cut edge with sandpaper on a block of wood to get it something like level, then touched up the white of the cut fiberglass with red
touch up paint. I was going to put edge trim on but that would have taken ages and looked a bit silly.
I then sprayed everything underneath that could be see black so it looked neater.
