I'm after a compact, portable, set of gas welding gear, anybody had any experience of them.
I know they won't be as economical as larger kit, but I want it for track days as an emergency measure.
If you have trackside power, then inverter fusion tig is really compact and robust.
Personally I think you would be better off with a small Honda generator and mig/tig invertor.
Carrying a gas set is not going to be great, if you are at any proper track you get electric in the pits.
Regards Mark
I expect it would be the rental that would kill it, otherwise the oxy/ace are the same you just have less of them so with a half good torch the
welding is the same as a larger set.
Else, Im very happy with my esab inveter mig set.
Daniel
I LOVE gas welding, such an art to perfect, but I was under the impression that the required safety certs etc pretty much ruled out DIY use above MAP type gases?
