Can anyone point me in the direction of a locost rivnut stud tool?
FIXM6SRNSHSPWH 12.5mm M6 STEEL RIVET NUT STUD RIV-NUT STUD x12
Link is to show the stud. It's a stud not a nut.
I have a rivnut tool from memfast but that doesn't do the studs.
Any ideas? I did consider using a piece of tube with a bar on to hold it while I tighten a nut to it but I guess the stud would just turn in the hole.
According to MemFast this tool does both. Is this the one that you have?
[Edited on 17-12-12 by 40inches]
Unfortunately not. I have the newer version.
I have just seen there is a note that there will be a stud conversion out in 2012! I better contact them.
[Edited on 17/12/12 by rdodger]
Can you fit three nuts on the stud? Think about it. That would be my locost way.
J
J
May sound silly, but what's to stop putting a bit of threaded bar in a normal rivnut? Surely the same outcome? And with a bit of thread lock, wouldn't easily come loose....
I will be using them in the chassis for earth points. I want to use something with the best chance of sealing and not letting water in.
Ali rivnuts in steel frame add electrical current, equals Corrosion!
I wonder if MemFast sell the stud adaptor separately?
Why not just drill & tap the chassis, then use a bolt?
Try these - they work well, seal the hole, easy to put where you need them and will not induce corrosion and pretty near cheap as chips.
5 x Pop rivet earth terminals cars vans Land Rovers
May be too late now, but I always just weld a bolt to the frame, head down obviously...works a treat.
+ 1, and if you use a stainless bolt you can mask the thread when painting and the exposed bit will not rust and look bad later.
Fred W B
Belated reply but we have rivet stud conversion kits available now from M4 to M8 in plastic case - please see website.
We also have conversion kits for UNC & UNF Rivet Nuts - again please see website
I have had mine for a few weeks now and they work great!
