How would you go about making a tool to remove this cap without damaging it?
overall diameter is 28 mm, recess is 14 mm.
Cover recess with cling film and then pack with epoxy resin/chopped glass fiber mat?
now if only I had a CNC or 3D printer....
I reckon you could vabricate somthing from 5 bits of bar welded on to a central pin.
screwdriver with some duct tape wrapped round the end to avoid metal bits contacting each other.........Locost style......
figure out the size of the holes, cut down some bolts. Weld bolts onto bar. twist bar.
Technically you'd only need two bolts.
round bar equal diameter to of the centre of cap.
5 small round bar equal to the 5 outer areas.
bit of welding and grinding.
jobs a good'n
I have used large hex keys before with a piece of duct tape for padding on similar caps.
I have used the two screwdriver technique,... one in one slot as a pivot, the other in across the cap as a lever. It would be possible to replicate as
a bar with just two pins, or three if you were worried. Not all 5 are required.
hth
thanks - good job i asked - 5 aluminium pins held in some fashion would be the easiest
Tool for changing wheels on the angle grinder perhaps, difficult to gauge the dimensions from the photo, but could also be made to size with a bar an couple of bolts..
What about making a tool out of that plastic that you can melt in boiling water?
known a s polymorph
I think Iwould just drill hole centres througha bit of flat bar and drop some bolts through - either put a nut on back or a spot of weld on top, how
tight are they?
Have a cnc machine that works with wood and pladstic (but not metal on a big scale0
mIKE
Digitise the shape using TuboCAD or AutoCAD then cut it out of the solid, simples!
Looks a reasonably expensive part - is it for cycle brakes?
How much is the proper tool, might be cheaper in the long run to preserve the part. Don't foget you've got to do it back up again too.
Easy, all you need is a milling machine , a lathe and a rotary table!
That looks like a cap of a mountain bike brake calliper
Just like the hope one
Just buy the tool
Just buy the tool
