I hope this isn't a repost, I did have a quick search.
LINKY TO VIDEO
Neil
How do you embed a video?
[Edited on 1/1/13 by trikerneil]
I wonder if they do them for Landrovers?
Like them a lot!
I might make something like that.
Nice idea, the spring loaded pins certainly contribute to the ease of use. But as with so many other new jacking methods, the car is still on
it's wheels. Brakes and suspension work usually need the car to be off it's wheels, and most engine work is done from the top. I guess these
would make it really easy to fix an exhaust?
If the platform could be converted to work on the chassis rather than the wheels then I think it's a winner.
Originally posted by Slimy38
Nice idea, the spring loaded pins certainly contribute to the ease of use. But as with so many other new jacking methods, the car is still on it's wheels. Brakes and suspension work usually need the car to be off it's wheels, and most engine work is done from the top. I guess these would make it really easy to fix an exhaust?
I don't know how sturdy built these are but I would like to see them rocked back and forth a bit to see how they react. If I was working under
them I would still put a concrete block or big bit of wood in the middle.
That said they look fantastic.
Er, reverse onto ramps, handbrake on, jack other end then axle stands.
Why complicate things!
Simon
Been there, done that;
well, similar sort of thing. (insert smug grin smiley)
I use mine a quite a bit. Saves my poor old back.
Either under the wheels, or in the case of the second pic, under the wishbone of an MX5
for the infamous rear wheel arch to sill repair.
Cheers & HNY
Paul G
Stand under MX5 wishbone
Theyr quite a nice idea. i like pauls ones no buggering about with jacks.
i saw some at a show that had like a scissor jack incorperated similar to pauls.
