What's the best adhesive to fix aluminium to GRP? I need to fix some brackets to the back of the dash and don't want to drill holes through
it.
Cheers!
Personally I would glass them on. You can pickup a fibreglass kit in halfords for a tenner.
PU adhésive, surfaces keyed and grease free
Sikaflex
Tigerseal will stick poo to a blanket !!
Do you often need to stick poo to a blanket? You have some weird hobbies!
we used to use araldite 3000 and something at british aerospace, it would tear the aluminium before breaking the bond,. however I expect that is a
little extreme. The other excellent suggestion is 3M VHB tape, it is amazing stuff,...
hth
Just a saying mate, thanks for your recommendations just another wise arse with nothing else to do !!!
It was just some tongue in cheek humour because the actual saying is "will stick LIKE poo to a blanket". Do
you see? one is a reference to how sticky poo is, your reference is how well you can glue poo to linen? Ah, don't listen, winter brings out the worst in everyone. I think what we call JB Weld would work, but Sikaflex on a keyed surface should be OK. Fibreglassing onto ally is a dangerous thing, but maybe when keyed would be good. Tends not to want to stick, which is why using ally moulds works so well when fibreglassing.
