having never bought one before, could someone point me in the direction of an appropriate tool to engrave the vin into a chasis rail/ or a metal
plate?
I've seen some engraving tools on ebay fo r under 20 quid but that doesn't seem reassuringly expensive enough, on the other hand over
100 for a dremel and attachments ( as seen in b and q) seems quite a lot if I only use it to mark the vin!
[Edited on 11/5/13 by jps]
I used one of these, however not the easiest thing to do. I would suggest spend a little bit more and get the £29.99 kit as this includes a diamond
engraving point, which is a lot better than the carbide one.
http://www.amazon.co.uk/Dremel-F0130290JF-Engraver/dp/B000QGHR1I/ref=sr_1_2?ie=UTF8&qid=1368254086&sr=8-2&keywords=dremel+engraver
http://www.amazon.co.uk/Dremel-F0130290JK-Hobby-Engraver/dp/B002LARRRQ/ref=sr_1_1?ie=UTF8&qid=1368254528&sr=8-1&keywords=dremel+engraver
r />
[Edited on 11/5/13 by Coopz]
A set of punches is cheaper and IMHO easier to get better results with.
Note that a vin plate must be permanently attached to the chassis. Riveting it on is likely to fail, better to weld on.
Punches are much better, or get an engraving shop to make a couple in steel and just tack weld in place.
I use a cheap Aldi Dremel copy with a small burr for marking but as above letter punches are easier and more permanent. I cut a strip of 16g and stamp
then weld onto the chassis tube. One thing I find is start at the end and work backwards, it's easier to keep the stamps in line and evenly
spaced.
[Edited on 11/5/13 by Peteff]
Punches every time.
IMO punches are better if stamping a VIN plate then welding to the chassis, but if stamping directly into the chassis they just dent the chassis and fail to punch the letter/number clearly, an engraver does a far neater job.
I got a £5 battery one from Lidl, has a diamond tip and worked well.
Key makers and dog tag type places in the market will have a pantograph "Gravograph" type machine to do it neatly. How may times will you use an engraver after buying one for this??
