This might seem a basic question,
My fuel rail extrusion is 1/2" bore, what pipe thread sise do I need to use and tap the bore to take the feed and relief fittings?
Cheers.
Pete.
[Edited on 22/6/13 by r1_pete]
0.5" is just 0.6mm bit too big to tap for 1/4" BSP parallel ----
If the wall thickness is ok 3/8" NPT might work the tapping dril size is 9/16"
