I'm looking for M18 x 1.5 threaded rod, and as always it's 'challenging' to find. The only supplier I found on this side of the
pond is out of stock.
So, time to consider cutting a thread. I did it once in school and remember the technique, but I'm no engineer and was just copying rather than
learning. If I'm looking at an M18 thread, do I start with 18mm steel?
Yes, 18mm OD steel rod for M18 thread.
How long do you need the threaded pieces?
Dave
The inserts are 60mm long and I'm guessing the more the thread the better, so maybe 70-80mm times four? I had thought of finding suitable set screws and cutting the head off, but even that seems harder than expected.
Try Non Standard Socket Screw Company in Brum, they probably have them off the shelf
I got a couple 3/4 UNF bolts off eBay the other day, these are pretty much the equivalent if you are making up something, I wanted them to make a
puller
http://www.ebay.co.uk/itm/261206411703?var=560195347030&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Originally posted by mark chandler
I got a couple 3/4 UNF bolts off eBay the other day, these are pretty much the equivalent if you are making up something, I wanted them to make a puller
My rear suspension sits on 1/2" unf rose joints, 3/4" is more your commercial size, landrovers etc.
McGills sells threaded bungs to suit.
Regards Mark
my machinist could make those up for you very reasonably if you can't find off the shelf. I'm going to see him tomorrow I could get a price if you want
http://www.mbefasteners.co.uk/
Simon
Simon
Regards Mark
