Can anyone confirm the torq to remove the sierra drive shafts is a T40
That size required is angle grinder.
Can't remember the size, but can remember snapping a few, and resorting to what britishtrident mentions.
Grinder will be a bit tight to get in as its all still fitted to the indy i will get a Snapon torq if i can find out the correct size
come on help me please
Jacko
My sheared off one is a T40 which I think happened on these
buy a Halfords pro one, that way you will be able to take it back every 3rd bolt to get it replaced foc :-( you can get to them with a grinder, at least on the Avon we could....
My halfords ones survived it
And yes 40
The smaller sizes of Halfords ones are OK. It's the bigger ones that are poor, as the they all neck down to the same size shaft, which is weaker than the actual drive section! I've snapped T55s a number of times - including doing up cylinder head bolts with a torque wrench, so certainly not overdoing it.
I seem to remember (it was years ago) that the replacement bolts I got were a different size to the ones I couldn't get out.
Thank you for the info i will get 2 or 3 in the morning
Jacko
+1 for T40
but an angry grinder or cold chisel works better
(btw don't you mean 'torx' )
Yes, T40, after snapping 3 cheap ones, I bought a 25x dewalt (tic tac) box, they worked a treat so I still have 24 unused dewalt bits!
Originally posted by mcerd1
+1 for T40
but an angry grinder or cold chisel works better![]()
