Seen lots of these on ebay circa £10, but none seem to have the firm flexible necks, just bare floppy cable. Any one seen these necks on the cheap usb ones that dont have a built in screen?
I have one like this, it has a decent flexible wand and seems to be good quality
eBay Item
Reasonable picture and has a mirror that you can screw on the end so you can look at 90 degrees, mine cost £15 I think.
[Edited on 11/5/14 by mark chandler]
I have one of these type, think it was under £20 but only just.
Snake Scope Video Inspection Endoscope/Borescope
Reasonable for the price, if not i suspect a patch on the £250 ones.
Daniel
Minor note - make sure your engine is not cranked over by someone tinkering while the cam is down the bore or you have to remove the head to get the
slightly bent remains out...
Not seen the non floppy cams at the low price point.
