I need a shim made!!
number-1 - 7/6/14 at 07:57 PM
Can anyone point me in the right direction?
I need a tube/shim made for a motorcycle axle.......Stainless steel will be fine, Dimensions are OD 25mm ID 20mm D39mm....so its not very big! It needs a cut along the depth......something like this quality pic ive created lol
The cut is so it will pinch the axle when the fork lugs are tightened
Any ideas of who can make it and what i should be paying? Im in Aylesbury, Bucks
N1
adithorp - 7/6/14 at 08:40 PM
How about THIS
Slightly longer and without the slit but ten mins with the angry grinder would sort that.
silverback - 7/6/14 at 08:44 PM
U2U reply
number-1 - 7/6/14 at 08:53 PM
Cheers for the replies chaps
Good find adithorp! Almost the perfect length! Maybe the 1mm difference wont make too much of a difference! I will re measure tomorrow
Silverback, ive replied to your U2U
adithorp - 7/6/14 at 08:55 PM
I was buying poly-bushes and crush tubes last week.
