Any recommendation for an inspection camera/boroscope under 100quid. Not looking for a USB one.
I haven't tried their scopes but Autel equipment is generally good and not expensive.
I actually picked up one from Maplin last week to have a look at a mates engine which had a worrying rattle, it did the job, screens not the brightest
but then none I have seen are. the picture and video worked fine. The end isn't steerable but worked fine for what i wanted it for.
This one:
http://www.maplin.co.uk/p/handheld-video-optic-inspection-tool-with-lcd-display-and-recording-n85nh
HTH
I had looked at that one as well as this one
http://www.maplin.co.uk/p/ridgid-ca-25-seesnake-micro-hand-held-inspection-camera-r30bx
which is 80quid for amazon
I suppose they are much the same for that money.
That's the one I would have gone for but wasn't in stock at my local Maplin, that said the one I ended up with did everything I needed it to. What do you need it for? long term or a one off job? Dont want to sell it but if you just need to borrow it for a week or so I'm sure it could be sorted? PM me if a loan would do.
linky
Ebuyer has one for £50
I bought this one. It hasn't arrived yet but I'm away until Friday anyway.
Link
My only piece of advice is...
Make sure the engine is locked before putting it in the plug hole. If it spins over under its own steam you need to take the head off to get the
mangled camera out. Don't ask how I know
Lidl have them for £40 from 15th June.
any of you lads want to give me a reach around? or rim my asshole and tickle my balls... well endowed men prefered
Usually its called being fraped... but can you be LCBaped?
