Sealey VS820 Brake Bleeder = Brilliant Tool :-)
britishtrident - 18/10/15 at 12:58 PM
I recently bought a new pressure Sealey brake bleeder to replace my modified Eezybleed, my first job with it was to replace the front to rear brake pipe, after 2 minutes to set it up and pump up to 12 psi or so the bleeding was accomplished in 15 seconds.
Cost was less than £40
Only negatives are the the resevoir is a bit on the large size and it would be improved by a smaller diameter longer hose to ebable it to be used on the ground rather than balance on top of the engine.
Link to page in Sealey Web Catalogue
rusty nuts - 18/10/15 at 01:46 PM
Been using one for a while , as you say a longer hose would be better as well as a few different master cylinder caps .
