I have a 24 volt impact gun,the batteries are toast and it,s cheaper to buy a new gun than a couple of battery packs or new cells.
i have tried to re-juvinate them but they really are finished.
so...........would the power supply below do the job ?.
24 volt DC power supply enclosed switch mode 24V 10A 240W
I don't think that psu would be good for an impact gun.
a) its only 240watt
b) switch mode power supplies and inductive loads are a bad idea
c) as well as being an inductive load the gun has hugely changing power requirements
d) you loose most of the advantages of a battery tool
If you can live with losing the advantage of being wireless then two 12v car batteries wired in series would easily do the job. And easy to keep
charged up using a standard battery charger (disconnect and do one at a time)
Of course this is only really economical if you already have the batteries lying around
[Edited on 18/1/17 by SCAR]
thanks for the replies peeps,no spare batteries laying around and at the mo it is just taking up space,seems a waste to dump an otherwise hardly used
gun.
ill keep an eye out for some batteries then
You can buy brand new 11Ah (or thereabouts) SLA gel bike batteries on Ebay which would be way more than adequate for the job at around £22ea delivered
- I know I bought one for my booster pack when the battery finally died - bought a year ago & still performing as new & you don't lose
all of the portability if you make a little carry case for them, you can still charge separately with a normal 12v charger which you probably already
have?
HTH Russ
Cheers Russ,found some mobility scooter batteries,would they do ?
Been running a good 14v battery drill (no batteries) off a lead and an old car battery. Perfect if you're prepared to manage the lead, which I made up using the old battery case. Just don't want to buy another drill when I have 3 good ones lying around with no batteries.
Thanks all
take the batteries apart and replace the individual cells . just like they do on prius battery packs ....
priced up the individual cells and it came to near the price of a new gun,unless you know of somewhere a bit cheaper ?,they are "C" and
there are 32 of them in both packs
My DeWalt drill's battery packs all gave up near-enough simultaneously (it came with 3 packs). This was either due to no using them often or,
more likely, they were rubbish.
I did a bit of scouting around and found a supplier on ebay who sold me a clone battery pack for a fraction of the deWalt price. Of course, I had low
expectations - but in practice the thing holds its charge far, far longer than the deWalt packs, and continues to work despite being neglected as much
as the original units.
I'll see if I can find the supplier again...
Thanks David
