Does anyone have any experience using VFD's as speed control on single phase motors.
I have a 1.1kw single phase motor which I need to be able to alter the speed of.
Thanks in advance
Liam Mc
Thanks in advance
Liam Mc
Originally posted by Toys2
Unfortunately, You can't use a VSD with single phase motor, the option there is to swap the motor for a 3 phase 220V and then use an invertor with that
Sell the single phase motor and buy a three phase one? At that power you could run the VFD from a single phase supply still.
Alternatively, but physically more complicated, a variable speed pulley system - Variable speed
pulley system
Anyone want to buy a brand new 1.1kw single phase motor
Single phase VFDs are definitely available, though single phase motors have significant disadvantages over three phase so there would need to be a compelling reason not to fit a 3 phase motor and VFD.
Single phase induction motor requires a cap to start to give a temporary phase difference between the two fields.
It will run at the speed given by the feed frequency.
You could attempt to run a single phase motor from a 3 phase VFD (just using one phase output) but it's a total kludge and might trip out the
(unevenly loaded) VFD.
Yes there are single phase VSD's but they drive 3 phase motors. As far as I know, it's not possible to control a single phase motor due to the requirement of phase angle generated by the capacitor start
