Hi,
I'm still at planning stage and my thoughs are currently with chassis designs and how to build it. I can't even consider the expense of a
TIG welder so it's MIG all the way, besides I think a MIG welder is more likely to find other quick and simple jobs around the 'house'.
I gather the best bet is to get the most amps you can afford then run it lower rather than run a smaller unit harder? With this in mind my question is
about spool orientation. I'm looking at the SIP 150A range which comes in either the normal smallish unit with a reel upright or a slightly more
expensive and larger model with the reel on its side. I gather the side reel will allow easier welding with soft materials but will it make it easier
to get a good mild-steel weld?
Adam.
Been posted already in another thread, but worth taking a look
http://www.thewelderswarehouse.com/acatalog/Special_Offers.html
Bought my welder from there. Get accessories from http://www.welduk.com/ though
BTW the light-sensitive helmets are worth their weight in gold.
Soz - can't answer the horizontal/vertical question.
In my opinion horizontal or vertical makes no difference. Main thing is it needs to turn smoothly and have an adjustable "brake" on the reel
spindle to maintain a slight tension on the wire.
Hope this helps.
I have an ERP 150A mig, which i believe is exactly the same as the SIP, although i could well be wrong.
Anyway the wire feed units are quite weak with small plastic cogs which have a tendancy to break if any abnormal loads are applied i.e. wire snagging
etc. This has happened to me twice now, once trying out aluminium wire (not recommended on my welder).
As i say, the welders may be different, so dont take my word for it, just a point to check.
