Drill Sizes
kango - 31/1/05 at 05:43 PM
Anybody with a list of drill size to tap thread eg M5, M6 ect.
Found nothing on the SEARCH.
Hellfire - 31/1/05 at 06:03 PM
Good job I did then :
CLICKEE
Happy drilling!
mangogrooveworkshop - 31/1/05 at 06:15 PM
Good link Hellfire
Here is the calculator that I had some time ago
http://www.evergreen.edu/biophysics/technotes/fabric/js-tap.htm
[Edited on 31-1-05 by mangogrooveworkshop]
rusty nuts - 31/1/05 at 06:31 PM
If you haven't got a chart to hand find a nut the same thread as you need to tap and use the largest drill that will go through it, has got me out of trouble in the past
flak monkey - 31/1/05 at 06:34 PM
Another good indicator is the pitch of the thread on a small tap. (Think it works upto about M10)
If you subtract the pitch from the size then you get the tapping drill size:
eg M5x0.8 would be a 4.2mm drill. etc.
Bear in mind the tapping drill depends slightly on the material too. Harder materials use a bigger drill, softer use a smaller one.
