With a little bit of prompting from a mate,
I'm contemplating having a bash at making one of these.
Anyone ever used one ?
Aluminium wheel arches would be sooo nice.
With a bit of practice maybe even a nosecone ?
Paul G
http://www.eastwoodco.com/jump.jsp?itemType=CATEGORY&itemID=829
For anyone with a decent welder and a lathe, it could be a locost proposition?
Might get some ideas here: http://allshops.org/cgi-bin/community/cforums.cgi?forumid=109061855423990
and this one:
http://www.roddingroundtable.com/tech/articles/12ewheel.html
[Edited on 3/2/05 by mark_UK]
Originally posted by Browser
Had a look at that one and it looks great! I'll definitely HAVE to try and get the bits together for one and have a go........
[Edited on 3/2/05 by Browser]
Eddy White was selling a bench mounted version on ebay not long ago for something around £150.
The larger ones fetch a lot of money.
Martin at MK made himself a freestanding one quite cheaply I believe.
'ere you go: http://www.metalcrafttools.com/engwheel.html
You shouldn't need the plans, it all look simple enough.
Or, step by step: http://www.roddingroundtable.com/tech/articles/12ewheel.html
[Edited on 3/2/05 by timsta]
I'm sure that some of the FEA designers amongst us could present a minimum metal, optimised solution made from left over 1" RHS, a bit of
hydraulic tubing, used wheel bearings, and a pair of wheels for the diy toolers to fabricate.
Then we can all hum those old favourites whilst we fabricate such as:
We'll meet again..
4 wheels on my waggon..(sorry that's american)
Colin
Another one is:-
This shows how to make one, including the rollers, a "Ford axle bearing" and a "pillow block bearing".
I'd estimate £70 for the whole thing.
Paul G
There is a ton of metalshaping info here http://www.metalmeet.com/forum/index.php
I cant let this topic go by without posting this link.
for those making the full sized ones.
and needing anvils etc
look here for a us vendor who exports and for a resonable price
You could also look here
The Tin Man
The frame doesn't look too hard to a man with your skills - but the hardened rolls are expensive!.
Good replies chaps, but still want to find someone who has used one.
Anyone know where you can buy "casenite"? ( case hardening powder )
Paul G
Paul,
It's spelled with a 'K' - Kasenite or Kasenit - I know a few model engineering suppliers but they tend to sell small quantities only.
Blackgates Engineering is one - a Google will find them.
Otherwise it comes in big tins - £82 + VAT for 5kg is one I found!
You could take the anvils to your local engine refurb spot and ask then to nitride/tuffride them.
Originally posted by David Jenkins
Paul,
It's spelled with a 'K' - Kasenite or Kasenit - I know a few model engineering suppliers but they tend to sell small quantities only. Blackgates Engineering is one - a Google will find them.
I like the idea of the sugar Rorty.
I assume that it would catch fire if a red hot lump of steel was dipped in it.
At a lower temp it would turn to toffee.
Ummm, maybe I'll try that.
Paul G
907, if you have an oxy-acetylene torch and plenty of gas, just flame harden!
Get a rich flame going and play it over the part for a good while, then up the oxygen and blast it until dull red and quench.
It makes me think of my college days.
" The Products of the Oxyacetylene Flame "
O, the good old days.
Paul G
The day I start making the bodywork is looming, so I thought I'd better crack on with the "wheel".
It's cost me £48 so far, so a waste of money..... or a bargain?
I'll probably knacker loads of ally sheet,
then go and buy some fibreglass.
Paul G
Um... isn't the bottom wheel supposed to adjustable up and down? The real e-wheels have a big wheel at the bottom to adjust the roller
spacing.
Or is that bit hidden somewhere?
Yes, the anvil has to be adjustable. Here's my set-up:
907 will have made provision for this im sure guys, to make an english wheel you must understand how one works. I don't think it is as it
appears
i too wondered which bit moved, but to be honest, you'd need to be real stupid to make it with both wheels fixed and i assume he knows a
little more about it than me!
and his welding is far too bloody neat, git!
It's the opposite way up to Rorty's,
but then again, since he's in Oz it would be.
The vertical bit is 80 x 80 box. Inside it is a bit of 70 x70 and a thread runs
down the middle with a wheel underneath, (or it will have when it's finished).
The frame is 120 x 60 x 6.
I have no idea how strong it will need to be, but the plan is to have a throat
big enough to make an air scoop in a bonnet.
Any advise welcome.
Paul G
I didn't doubt your ability at all having seen some of your fabrication work before.
Does your Ewheel have a kick wheel for adjustment then? Some swear by them and some swear at them when they repeatedly anneal their shins on them.
That's the idea.
Thinking of M18 fine (because I have a tap that size).
Is the finer the better?
Paul G
Originally posted by 907
That's the idea.
Paul G
Paul, might be able to help with a larger tap. Possibly up to 22mm if it's any help .
Is that M22 fine (x1.5)?
If it is, that would be great Melvyn.
I have all the normal metric taps up to 24 and brakes (10x1), fan switch (14x1.25), and the w/bones (18x1).
At £20 ish apiece I grudge buying them just to cut one thread.
Paul G
The wheels nearly finished.
Just a few probs to iron out; like get rid of that spanner hanging on the bottom.
AND IT WORKS
, well sort of.
Now where did I put those ally offcuts.
Paul G
WOW, 1000 hours of practice and I should get the hang of this.
and what's more, I'v still got my thumbs.
Pic below is a bonnet bulge for a Fiat 500
Paul G
And how smooth did it end up?
Looking really good though.
Will there be a spurt of wheel arches like the cans?
Pat...
WOW, 1000 hours of practice and I should get the hang of this.![]()
Paul G
Originally posted by Avoneer
Will there be a spurt of wheel arches like the cans?![]()
Pat...
Doh
looking good, cant wait to see more results
Originally posted by Gaz 1977
looking good, cant wait to see more results![]()
I cant believe that mother used your head as a former for the ally
First of all, many thanks for all the assistance I'v had with this little project,
especialy Melvyn, (Rusty Nuts) for the loan of the M22f tap, delivered it too.
It's now finished. All I'v got to do now is learn how to use it.
From the pics I'v seen on the net, I'v come to the conclusion that they have
to be painted a realy revolting colour, so mine's "poppy", to match my eyes.
Many thanks everyone,
Paul G
Very nice too. Well done. Can I have a set of 18/10 saucepans please?
Originally posted by Rorty
Very nice too. Well done. Can I have a set of 18/10 saucepans please?![]()
18/10 being the stainless material to really test your skills, but since you're offering, I do need a new jam pan. I'm not allowed to make
my marmalade in the copper one anymore as it has been elevated to ornament status!
Paul G
PS Just scrolled down and seen the finished item - very nice!
i saw a chap on american chopper using one, was suprised as i hadnt realised you just pushed the metal back and forth!
Originally posted by JoelP
i saw a chap on american chopper using one, was suprised as i hadnt realised you just pushed the metal back and forth!![]()
An old friend of mine in Somerset used to make replica aluminium racing bodies for 3000l Healeys and he made the front wings from a single sheet of ally! (The factory ones were made in two pieces and joined.)
Hi Paul if you are in Northampton one day give me a call i will take you to were i work Im Sure you will like it regards Trev.
Originally posted by Trev D
Hi Paul if you are in Northampton one day give me a call i will take you to were i work Im Sure you will like it regards Trev.![]()
Week ends best sort out which week end you have free and let me know then we can sort out the final details.
regards Trev
regards Trev
Thanks Trev for the tour of the workshop, the hints, tips and advise.
Your a Saint, a God of the metalworking world.
Thanks again for your time.
Paul G
Hi Paul glad you had a good time. Good to meet you again hope to see you soon all the best Trev.ps like the picture.
