Just out of interest, how much welding gas does everyone use to build a car? I'm going to be picking up bottle number 4 today, and while I doubt
I'll actually use very much, it did seem a bit much that I've used three 10 litre bottles to do 99% of the car. It's Adams gas so it
hasn't cost very much over the years.
Thinking about welding wire I think I've used at least a dozen of the 0.7kg reels, it might have made sense to get a bigger roll earlier on but
my welder didn't seem to have the capacity for the bigger rolls.
Depends what you're doing, I guess. Straight forward kit build, or plenty of trials and scrap.
Even just modifying, etc., I get through 5Kg reels frequently. 0.7Kg reels are ridiculously small. Used to have a BOC Argoshield 'W' for the
gas, but I've now gone to 'Y' (the smaller one), due to a need to take a welder to the circuit... just in case.
Migatronic 5000, SIP Autoplus 100 and my RTech 180 all take 5Kg. The Clarke 255 eats 15Kg as an option, but I stay at 5Kg (refreshing rather than
watching the wire corrode).
Even just modifying, etc., I get through 5Kg reels frequently. 0.7Kg reels are ridiculously small. Used to have a BOC Argoshield 'W' for the gas, but I've now gone to 'Y' (the smaller one), due to a need to take a welder to the circuit... just in case.
Migatronic 5000, SIP Autoplus 100 and my RTech 180 all take 5Kg. The Clarke 255 eats 15Kg as an option, but I stay at 5Kg (refreshing rather than watching the wire corrode).
I’ve used Hobbyweld for gas so no ongoing cost. Would think it’s definitely been the cheapest way for me given the number of years it’s been, but then I haven’t welded the full chassis, just small bits and pieces along the way.
I think I used about 8-10 recharges of my 10 litre bottle of argon, the first fills were about 75€ back in 2019 and last week when I went to refill it it was about 110€. Thankfully the car is done now so this fillup should last me a good while.
My entire build was somewhere in the realm of 10-12k £ but then I didnt try to build as cheap as possible at all. The things I bought used was
engine+engine wiring and ecu, gearbox, differential, rims, front and rear uprights/hubs.
Edit: forgot the steering column.
250 £ today buys you the material for the frame and A-arms, not much else unless you manage to go with rusty cutoffs from someones scrap pile.
[Edited on 1 by falcor75]
I went through 1 0.7kg reel patching 2 sills on my tin-top, sounds like you're doing well.
Honestly though, sounds like you took the right route and it has worked out pretty well, I wouldn't go for bigger reels even if I needed them
because they end up rusting in my damp garage, I'd rather have 5x good reels than 1x constantly decaying roller faff.
I have an account with BOC for Argon for my TIG, but I haven't used it yet - it looks super cheap for DIY stuff, but as you say, if you're
taking years to build it, the rental would go above the gas cost.
