Where can I get this stuff in the UK? and more importantly is it any use.
I tried Frost.co.uk but couldn't find it, I was sure that is where I saw it.
I am going to cut out a section of my rear inner and outer arch on my Prelude and know that as I weld I am likly to distort the res of the panel. I
have seen this stuff in magazines but don't know if it really works. I know that I will have to wled the outer wing in very small steps to
minmise the potential damage and just thought this would be an added safety factor.
I can find it in the US - Here ->
Here
[Edited on 15/3/05 by ewanspence]
frosts do it for sure, cant remember the name of the stuff though. Sorry
It looks like putty.
http://www.frost.co.uk/item_Detail.asp?productID=8822
I've welded replacement arches on several different vehicles with the mig and never had a problem that a fibre disk and a bit of filler
wouldn't fix. A 1/2" tack every couple of inches is enough to secure them, just make sure they are tight down to the parent metal and
it's clean.
[Edited on 15/3/05 by Peteff]
thanks for the info. Order now placed.
There's another brand of heat absorbing compound called Anti-Heat which is available in cartridges and cans. Same stuff really but I think it's Merican.
