sip 130
lexi - 6/9/05 at 10:37 PM
I`ve got 130 mig and it`s been a good little budget machine for the last 4yrs. I use boc argoshield. When shroud is spotless clean it produces nice welds but after 5mins when shroud is dirtier it`s nowhere near as good till I clean everything up again. Have gas between 6 and ten. Do all cheap migs do this?
Alex
Triton - 7/9/05 at 06:41 AM
Use anti spatter spray in the shroud after you have cleaned it out....spatter sticks to them after you have scraped them ....new one won't until you start poking screwdrivers/files side cutters up the spout.
But you really are better off with a "real" machine such as a Cebora with euro torch etc.
Mark
Gav - 7/9/05 at 08:17 AM
When i used to do a lot of welding at work i used to dip the hot shroud in a antispatter wax
would would last a lot longer than the spray stuff. Should be able to get it from any good welding supply shop
lexi - 7/9/05 at 09:57 AM
Thanks guys
Was looking at Craftmig 180 by Cebora but was wondering why it is cheaper than most other 180 migs. Is it because it don`t have a copper wound transformer. Triton. would you say that model was a "real" mig.
Alex
lexi - 8/9/05 at 11:17 PM
anybody any comment on Cebora craftmig 180?
Alex
Peteff - 9/9/05 at 12:52 AM
If it has an aluminium coil I would be wary if you were going to use it a lot. It's not a problem for the amount of use a hobby builder would expect. Cebora are a well respected make and I have used a couple and found them perfect.
