welding helmet
theconrodkid - 25/10/05 at 05:47 PM
looking at getting an auto welding helmet,there are soooooooooooooo many types out there,what is best,solar or battery,any makes/supliers to go for /avoid?
David Jenkins - 25/10/05 at 05:50 PM
For a start, get as big a 'window' as you can afford, and get an adjustable one if possible.
Peteff - 25/10/05 at 06:07 PM
Don't get a cheap battery one off ebay. My mate got one and it's crap, like welding in fog even when the visor is clean.
planetester - 25/10/05 at 06:15 PM
I read somewhere that the solar powered ones have a lithium battery that lasts about 8 years & is not replacable, I bought one of these http://autodarkhelmet.co.uk/product_info.php?cPath=23&products_id=29 the bloke seemed ok, it works ok & you can buy replacement parts from him, I'm no expert though
Surrey Dave - 25/10/05 at 06:41 PM
I got a cheap battery mask £30 ish off Ebay but it does not seem to darken enough now, could be that it eats batteries............
planetester's one looks exactly the same as my Ebay jobby!!!
[Edited on 25/10/05 by Surrey Dave]
paulf - 25/10/05 at 08:25 PM
I have a solar powered one and it packed in after least than 5 years.I cut the unit open and found that it has two 3v rechargeable cells in it, one of them was dead.As i needed to use it then, instead of trying to obtain a replacement I removed the solar cell and built in batteries and soldered leads to the board to allow me to connect to a battery pack made of 4aaa batteries soldered together.
It now works a treat and doesent pack in like it used to do if left in a dark workshop.
Paul.
Triton - 25/10/05 at 08:38 PM
ESAB Eye Tech....will last for ever if you look after it
Fozzie - 25/10/05 at 08:38 PM
Recently got a Jackson 'Attitude' auto-darkening with battery. It has 3 x settings on the inside which makes it good for every type of welding.
Very light, very good, and eermm a tad expensive
Fozzie
paulf - 25/10/05 at 09:02 PM
Mine is a ESAB eyetech but was left in a dark workshop all winter , i dont think it liked it.
paul
JoelP - 25/10/05 at 09:56 PM
by solar, i always thought they meant that it used the radiant energy from the arc to power it? would certainly make sense...
britishtrident - 26/10/05 at 07:59 AM
I bought one of these recently
£50 with spare clear lense
http://www.weld-tec.co.uk/Solarhelmet.htm
splitrivet - 26/10/05 at 09:22 AM
paul
Both myself and my lad had one left in the garage over winter and the cold weather screwed em both.
Bob
theconrodkid - 26/10/05 at 04:46 PM
i,m worse than a woman in a shoe shop here,think ill go with trident tho,ta for all your other sugestions. http://hotproducts.alibaba.com/manufacturers-exporters/Welding_Mask.html
these lot seem to make everything,what about an "import co"l
[Edited on 26/10/05 by theconrodkid]
johnjulie - 26/10/05 at 07:44 PM
Simple, get the best you can afford, there is nothing more annoying than learning to weld and you can't see what you are doing!
I got a new Optrel mask off Ebay for £120 expensive, but brilliant to use.
Cheers J&J
paulf - 26/10/05 at 07:50 PM
Thats how I thought it worked but its not the case .The solar cell just charges the inbuilt batterys there is a small sensor that detects the arc .
Paul.
