Does anybody have any views on the above welder as on
http://www.thewelderswarehouse.com/acatalog/Arc_&_Tig_Welders.html
It seems to be a reasonable buy
Made in China and appear under different brand names including Sealy . Keep an eye on ebay as they turn up in container loads someone might have them
cheaper. I got a DC Tig from this manufacturer branded Powershack at Christmas. It works fine and only cost £120 including TIG and ARC torches!
Caber
As I understand it, all BlueWeld stuff is actually manufactured by Telwin
Telwin already had a UK agent, so they supply The Welders Warehouse under the BlueWeld brand.
I splashed out on a BlueWeld plasma cutter a few months back and it's been great - no problems.
Dan
Originally posted by caber
Made in China and appear under different brand names including Sealy . Keep an eye on ebay as they turn up in container loads someone might have them cheaper. I got a DC Tig from this manufacturer branded Powershack at Christmas. It works fine and only cost £120 including TIG and ARC torches!
Caber
It is scratch start. I don't think the seller hass any up now but he was going to get more at some point soon
Caber
The 175 HF is as it says HF and you can get a foot pedal to work with it as well
Hi,
Have you used a Tig before?
Paul G
Paul
Yes I used one at evening classes in Bury and personally found it easier to use than MIG.
OK, I was going to say have a go with mine before you buy one,
just in case you didn't get on with it.
Since you've used one you know what to look for.
atb
Paul G
Paul
Thanks for the offer
I should be OK
