Afternoon all,
I'm trying to find somewhere that sells bits for use in a power screwdriver (one of the handheld motorised screwdriver thingies made by Black and
decker). It uses the standard 1/4" hex fitting.
What I am after are some hex drivers (ball ended and non ball ended) but extension ones for getting down into awkward places. Ideally I need the
shaft to be about the same size as the head of the driver, and at least 3-4" long. I am after 1mm, 1.5mm, 2mm, 2.5mm and 3mm sizes.
Does anyone know where I might be able to find any of these before resorting to hacking about some allen keys? I'm not too keen on cheap and
nasty, but if that is all there is out there, then that will do!
Actually, I've just had an idea for an adapter type thing if I can't find any to buy....
Screwfix,
They do the lot .
rswww.com
search for "hex bit set"
magnetic ones are better in most cases, i find my dewalt one to be very nice, its about 3" long.
