Hole size rule of thumb for taping 1/2" UNF ?
PHULL - 31/7/06 at 08:38 AM
Gday
Could someone help me with what size hole I should drill first and tap a 1/2" UNF thread.
If there is a rule of thumb to what size hole you should drill?
MikeRJ - 31/7/06 at 08:47 AM
Get yourself a "Zeus" book, it's cheap an invaluable for this type of information.
For a 1/2" UNF thread, a drill size of 29/64" is required, which is almost exactly 11.5mm.
mitch2b - 31/7/06 at 08:49 AM
this should help
http://www.coastalfasteners.co.nz/tapping_size.htm
Mitch
nick205 - 31/7/06 at 08:50 AM
yup the man from Zeus he say 11.40mm drill size for 1/2" UNF.
Local tool or nut/bolt factors should be able to furnish you with a Zeus data book - a worthy addition to any tool box
PHULL - 31/7/06 at 08:54 AM
Fantastic
thats for your help
Confused but excited. - 31/7/06 at 06:25 PM
Yep, that's close enough.
Peteff - 1/8/06 at 12:12 PM
If your thumb fits in it's too big
rusty nuts - 1/8/06 at 05:12 PM
If you haven't got any information to hand a usefull tip is to find a nut for the thread you need to cut and use the bigest drill bit that will go through nut.
