Nylon bearing?
rayroni - 7/11/06 at 10:19 AM
I'm in the process of fabricating a throttle linkage, which will have a roatating metal arm. I plan on 'mounting' this arm to a bolt.
However, how do I stop the arm sticking on the bolt, suspect I need some type of bearing.
Is nylon/plastic suitable and if so where can I get something suitable, or are there any other suggestions?
Thanks as always.
nitram38 - 7/11/06 at 10:28 AM
I have used nylon rod ends from RS componants, on my gearchange. The steel ones I used a first tended to bind up if the smallest amount of dirt got in. The nylon ones will allow for a rod to slide through them without binding. I sprayed them with some white grease which helps.
I haven't had a problem since.
Confused but excited. - 7/11/06 at 11:41 AM
The choice of bush material is determined by which is easier/cheaper to replace. A brass bush will wear before the steel bolt. A nylon bush will absorb grit and dust, but the bolt will wear.
CairB - 7/11/06 at 12:39 PM
I used a pair of oilite bushes for my home brew throttle linkage. No problems after over 5k miles.
David Jenkins - 7/11/06 at 01:09 PM
You can get proper bearing nylon - I think it's loaded with graphite or something. Just as machinable, but makes a respectable low-stress bearing (like a shaft support).
CairB - 7/11/06 at 04:39 PM
I think it was called Nylatron, loaded with molybdenum disulphide.
By using loctited oilite bushes I was able to ensure that the bearings were aligned so that there was no binding that can occur with low precision assemblies.
