Still Havent used My TIG Welder
The Baron - 27/2/07 at 06:00 PM
Ok.
I ordered some 1,6mm electrodes in order to start some practice welds but, when I assembled the TIG torch. The collet would not grip the electrode. The welder’s warehouse does not seem to supply the correct one. Does anybody know where I can get some? I assume that everyone else from the group buy has managed to get up and running by now. Or have I got a different torch to everyone else?
See the picture below for the type of collet.
The Baron
tig2
tig2
fatfranky - 27/2/07 at 06:03 PM
Hi
Not sure what type (WP??) of torch it is but i just took the little blue bag with the torch in it to my local supplier who at first looked puzzled (like it was not a common torch) and then found a bag with some in.
It cost just under a fiver for one set of collets.
Hope this helps
Regards
Frank
SeaBass - 27/2/07 at 06:09 PM
I got three collets with mine... They grip 1.6, 2.4 and 3.2mm I think...
I've certainly used the 1.6 & the 2.4mm
oliwb - 27/2/07 at 07:03 PM
They're standard torches....there's nothing strange about them but they are commercial spec so some of the more hobby places seem to be a bit bemused (in my experience)....as someone said I got 3 different ones with mine to account for changes in tungsten sizes. What are you welding?? 1.6mm is generally for thin body work type stuff as far as I can tell...I've been using 2.4 on almost everything including ali manifolds etc....Oli.
Gav - 27/2/07 at 07:45 PM
i replaced the supplied one with one of These and is a far better quality than the original imho, wasa bargin at £35 too!
[Edited on 27/2/07 by Gav]
andrew-theasby - 27/2/07 at 11:30 PM
Try this
http://www.locostbuilders.co.uk/viewthread.php?tid=60738
NS Dev - 1/3/07 at 05:33 PM
worth getting a triggerless torch if you are getting a second one.
I have a WP20 triggerless one and its small and very light, easy to get into tight corners with and you don't need the trigger if using a pedal, much easier to keep steady when starting the arc.
