Just remembered to ask this. When I was welding yesterday I was watching the wire and the weld and it was like there was a magnet at the side of the of weld or summat cos the wire kept twitching away from the weld pool occasionally and spoiling that nice finish. Any ideas?
I have also noticed that once, but it was when I was rushing a job for someone at work (when I really wasn't meant to be even in the "off
limits" workshop) and I hadn't done a thorough job of cleaning/grinding/wire brushing of the welded area...
I've heard of a similar thing when the welding tip starts to wear, and the wire comes out and moves around from where it has been curled up in the spool
Hmm, I'd gone over the area with 'the thing' to remove the paintwork first, maybe it was summat to do with some of the residue.
Cheers worX
I'll check the tip too. Never sure when/what the symptoms are to say it needs replacing.
No probs, Now that I come to think about it, it also happened once when I was being lazy and was resting the outer nozzle of the tip on the work
piece, so I think (and am making this bit totally up!) that it maybe had an easier arc out route - or something like that???
Cheers worX
Well I hold the neck with my other hand cos, to put it like someone did on here earlier, I shake like a shitting dog if not
but I did have the
outer nozzle close to the chassis rail, good call worX.
Hi All
One reason could be....
If the wire momentarily arcs in the tip, and the wire feed unit still tries to force the wire through.
This results in a kink, (or several kinks) in the wire, that you only notice when it emerges from the tip several seconds later.
Possibly, another welding mystery solved.
Paul G
Let me guess, its a Clarke, SIP or other hobby welder????
Simple one to solve, you need a better welder! (or bigger wire spools)
I used to have the same problem, its the curl in the wire as it comes off the reel is not removed properly as these welders have no wire straightening
provision, and thus the wire tries to curl up as it leaves the torch. For a while it will curl one way, then when you are used to that, it changes its
mind on you!
Plus side, if you notice this, your welding is improving and probably pretty reasonable!
Try turning the wire feed right up and discharging a load onto the floor, you'll see what I mean about the curl and how it moves around.
[Edited on 29/3/07 by NS Dev]
I used to have the same problem, its the curl in the wire as it comes off the reel is not removed properly as these welders have no wire straightening provision, and thus the wire tries to curl up as it leaves the torch. For a while it will curl one way, then when you are used to that, it changes its mind on you!![]()
a common problem is the wire clutch where the wire goes through the wheels if the wheels are squeezed together to tight the wire will curl as it comes out try loosening them.
I've pissed around with that wheel loads so I'm sure it weren't that. Did a bit today on the steering column and changed the tip,
cleared the shroud of clag and cleaned the parts with the 'thing'. Think it was sorted but I can't weld tube that well. Got a shaky
hand so need to use both to weld so can only do a wee bit at a time.
Cheers for all the replies
Chris
